simon mcnamee
I am looking to wire a pipe stat to my stove but dont know how to wire the junction box that the pump and stat go into, it would be well appreciated.
Discuss how to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
Is this a new install or existing. Do you know what you are trying to achieve by installing a pipe stat? Do you know how the system is plumbed? Not enough info provided.
like what mark says, or when the pipe gets too hot, the stat opens and the pump stops.the pipe stat is a switch. when the pipe gets to a certain temperature the switch will close. permanent live one side of the stat, switched return from the stat will join to the pump. neutral straight to the pump. hope that makes sense.
Simon, I started to do a drawing for you but my judgement got the better of me. You obviously don’t know what you’re doing, please get someone that does!
Sorry if that sounds harsh but I will not be a party to giving information that could be misinterpreted.
have to agree, what you describe won't get you noticed for the latest NASA project, do you have a specific sticky point?, cause if you do ,fire away, i will help.
i'm going to fit a cylinder stat . Is it ok to wrap it round the header tank in the attic ?
Reply to how to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
