Discuss Help with three phase power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gavin26
Hi I need some help with 3 phase wiring. I'm fairly confident I'm right but haven't done it since I was 18. Would I be right in saying that normal 3 phase power for sockets are wired in star and you should end up with 5 cables at each outlet? L1, L2, L3, N & E? With a 3 pole isolator for phases.Also do they have to be wired separately? Or can they be wired as radials?
I've been asked to do some industrial work (which I don't normally do!) what sort of thinks do I look for in regards to sized of cables etc what is the formulas for cable calcs on three phase?
I have a picture of the way I think they are wired but can't upload it because I haven't posted 5 times! Will upload once I can!
Appreciate responses
i think from your post you really ought to get someone with 3 phase experience to help you on this job. it's a lot more complex than just wiring up a radial with a few sockets.
1 What are the sockets to be used for
2 What load on each socket
Personally I would wire each outlet on seperate radial with a switched / isolated s/o (M.K. Commando range 16a - 125a ) but as Tel say's if your not sure ?
I have done 3 phase sockets as an apprentice but never been incharge of the design. I know it's different calcs to single phase etc. probably best getting somebody in with me then!
jesus some off you's need to chill out
it's really not that hard but need a few bits of info
what size sockets?
how far is the cable run?
how is the cable installed?
grouped cables how many?
proposed protective devices?
ambient temperature?
Hi ranger thanks for response. I know what the guys are saying but would just like a head start. I will in the end hire someone with 3 phase experience.
I couldn't tell you length of runs etc yet but it will more than likely be ran in conduit. Could you tell me the 3 phase formulas
we all learnt once!
which is why i suggested he got some expert help with the job. it may be to power motors or other industrial equipment. get it wrong and you're in it up to the neck. apart from that, public liability insurance may not cover him for 3 phase.
there is a we bit to observe and i am only learning it so sorry i cant help you as i dont fully understand it cause im a we fish in a big pond but i bark
How many electricians check their insurance before every job to see if they are covered, would seem to be a stupid exclusion for an electrician
it's common. just a way for the insurance companies to screw more out of you.
If you were using just one out of the three you’re almost right. Try 400/1.732 instead.
But if you have unbalanced load on each phase interacts with the others giving the 1/3[SUP]rd[/SUP] harmonic current.
For a balanced load (P/3)/(V/√3) = In. but the currents cancel themselves out making the neutral unnecessary. Run a neutral to a star connected motor and it won’t be a happy bunny.
Get some decent cable calculation software (cd). It requires the inputs you need most. As with alot of things you don't know. Do your research. Add it up. If all what your powering is 3 phase then n is ok.. So long as your circuit is rated to your breaker then you should be ok..
As I said do your research, and if its safe it is safe!!!
pure inductive load , and what about these super conductors in sern
my questioning comes from a lack of understanding on my part not questioning yours but as i was taught
Ib = P/(400x1.732xpf) example 10kW so 10,000/(400x1.732x0.8)= 18.04
selection of protective device
In= 20A
then It = In/rating factors ca cg etc
then on to VD
mVxIxLoR/1000
Multiply 400 by 1.732 and you get 693.
Despite that the answer is right? Somehow?
:bucktooth:
i dont understand 3 phase at all.... il have to start off like for like swaps and build on it...
the sums you have done below is that for 3phase circuit breaker and 18.04A will flow on each phase????
or isit a sum of a sum multiplying by a sum, yeh one of them ones;)
whats is loR in vd sum??
In= 20A
then on to VD
mVxIxLoR/1000
Oh come on. something that you freely admit you don't understand but you're still prepared to work on it and use that to further your knowledge?
If you don't understand it you should leave well alone. For example, guys like Tony work with massive voltages on huge transformers without any real worry on a day to day basis. Now I've done the theory of this stuff when I served my apprenticeship but the practicalities of doing it? No bloody way man. And that's because I have zero experience of it
well ive worked on jobs which had 3phase boards but never have 3phase equipment... i dont design install 3 phase equipment, just nosey
so ok,
i lied above have worked in a cafe which has 3 phase ovens.. but never designed and installed one from scratch...
so say i haqve circuit to design and install for one of these ovens where do you start from,, can you give me insight, we are only moving into 3phase theory next week in classes, so now i tell you this you can tell i stay well clear..
So you have taken on a job for which you have no idea how to do, you have no idea of the theory or the practicalities of it and you want to get guidance from the forum as to how to carry this work out?
It's not that difficult at all, not some 'Black Art' that some might like to make it out to be.
I'll recommend some reading if you want.
It's just the extra danger of a potential (!) 400 volt shock that you need to be wary of.
interested archy on 3 phase calculations, since ive started ive spend hundreds on books along with my courses and i can grasp single phase installations..
i know want to move on with 3phase and learn about it.... none of books i have mention 3phase in great detail...
so yeh ill fill me boots on your offer...
Reply to Help with three phase power in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
