S
solarcat
Hi All, before we ask the Client to spend any money on a new EPC assessment..do you reckon there is any chance they can get to D if they fit a 1.5 kWp system (nice south-facing roof)?
Discuss EPC F...can get to D with a 1.5 kWp south-facing PV system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
YES the option above may be better idea
I have just tried to find the link that Ted posted, but I can not find it, sorry.Earthstore can you post new or not so new regs regarding conservation areas..?????
My planning application was in Sept last year which predates the document in your link. At the time my local planning dept advised that permitted dev rights for Solar PV had been removed when the property was built. However another installation of mine in the same village, also within a conservation area, still had those rights and I was advised that planning was not required.Methley, It would be interesting to know which permitted development rights were removed, because PV permitted development rights come under 'Part 40' of the relevant Act.
Surely if you want to get a better tarrif after APRIL, you need to improve the house itself which leads to get the better tarriff for the PV Install, not the other way.........
I thought this was the case.
You had to have the D rating Before the solar pv is allowed at the higher 21p tariff, NOT taking into account the solar PV for the rating, can you confirm this is correct?
Reply to EPC F...can get to D with a 1.5 kWp south-facing PV system? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
