Discuss Antiquated incomer........... in the UK Electrical Forum area at ElectriciansForums.net
GBDamo
Any of the site historians like to explain what this is all about?
It looks like one side is a 40A main fuse but the other, exposed, side attached to the 15A switch?
By the way it was open when I got there, honest.
Need the DNO in to put in an E7 meter and teleswitch, if that's how they still do it.
In the cutout you've got a 40A fuse and a solid neutral link which has been put in to replace the original neutral fuse.
Not sure what the 15A switch fuse is doing.
Is there a BS number for this type of fuse, can't see anything on the housing.
Before British Standardisation?
Reply to Antiquated incomer........... in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I've come across this incomer, looks like 10mm conductors. The dno has upgraded the meter and used a 100A fuse. So my question is, does this...
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor...
