Discuss DNO Cables Running Under Soffit Across Houses... in the UK Electrical Forum area at ElectriciansForums.net
OnlQQker
Just wondering what your thoughts are about this before I renew the facias/soffits/guttering.
Any help would be appreciated as it's my sons new house.
I've attached some pics
there nowt wrong about DNO lashing a cable to the house ,its better to have them strapped to the wall or a great big pylon in the garden ,are you going to stick the table and chairs to it and the brolly .get on with it .lol.
Are the cables visibly damaged or looking brittle?
if so report it as a safety concern to your electricity supplier.
Reply to DNO Cables Running Under Soffit Across Houses... in the UK Electrical Forum area at ElectriciansForums.net
I'd appreciate the wisdom of domestic sparks here... End terrace early 20thC house: Supply: I've not seen the likes of this before in a house...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hey everyone, working on a new build house and outside garage is wired up like this, however customer wants a Garage Consumer Unit instead of the...
