Discuss 18th edition and bonding to gas and water in the The Welcome Forum area at ElectriciansForums.net
hi,
I have my 18th edition exam booked next week. I have just started to read up on the changes.
I am correct in stating that if the gas and water pipes have a plastic insulated section. At point of entry, then they do not require 10mm bonding??
Sorry if this is a stupid question....
Then my question is - if bonding was there, but now not required by the regs and we were doing a rewire (say) would we remove it or leave it in place? I would be leaving it, but I'm not sure that's right (?).
Ok so Im driving myself crazy with this.
Gas Bonding Question.
The gas supply is fed up to the property (domestic PME ) underground in plastic pipe. It comes out of the ground in plastic to a meter box.
The feed into the property enters in copper.
Does the gas need bonding.
Picture to help
No it doesn’t
What earth potential does a plastic pipe buried directly in the ground bring into the installation?
Only if plastic pipe is entering the building we only have the OPs word that it's plastic, Sorry misread the thread thought the OP said it entered in copper my bad apologies, Ian.
Sorry, for some reason the forum keeps automatically shortening the URL not sure how to post a url without it doing it ?
Wiring matters 76
Or
https://electrical.------.org/wiring-matters/issues/76/
If either of these don't work google wiring matters issue 76 protective bonding habits.
Reply to 18th edition and bonding to gas and water in the The Welcome Forum area at ElectriciansForums.net
having failed my first attempt at 18th edition exam, does anyone have any tips and tricks on how to study for the exam? being that there is a...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
evening everyone . Quick question here I’ve recently took over a job that a friend of mine first fixed it’s a 3 bed semi house rewire. I don’t...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
