Discuss 2 Appliances hard wired. in the DIY Electrical Advice area at ElectriciansForums.net
K
K-Linerz
Hi,
I have recently bought 2 kitchen appliances that need to be hard wired in.
Pyrolitic oven that is 3.84kW + Induction hob that is 7.4kW.
I have in my kitchen 1 point to wire in where the cooker would go. I know i cannot fit the 2 in one unit so what would need to happen.
Can the single point be converted into a double so that they can both be wired in?
The house was made in the 1970's and has had a replacement main fuse box within the last 10 years.
Im no good with the lingo and my electrical knowledge stretches as far as replacing light fittings, switches and sockets but thats it.
Many thanks :)
if cable supplying it will be adequate then it should be possible. best to get a local electrician in to asses the situation...
Hi,
Many thanks :)
With a possibility of 48 amps not taking diversity into account I would prefer a separate circuit for each item imho
I would also go with 2 x separate circuits. Or possibly not go for the induction Hob. Would it be fairly easy to instal an additional circuit?
convert the cooker outlet to a dual outlet. as long as the feed is a 6mm cable protected by a 32A MCB, it will be fine.
Reply to 2 Appliances hard wired. in the DIY Electrical Advice area at ElectriciansForums.net
I purchased a new-build apartment 10 years ago, which came with a fitted oven and microwave. Both appliances are described by the manufacturer...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hi All, I'm looking at installing an induction hob in my kitchen (upgrade from gas) and I gather that it can be added to the cooker circuit if...
I’m going to call an electrician out on Monday, but curious if anyone has any ideas about this fault: I have a new kitchen fitted and two...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
