Discuss 2 way columbus press switch in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Evening all,
I fitted 2 columbus press switches today to control 3 lights. I wired as it explained in the diagram and they worked fine. But I found that if you push the either of the switches to turn the lights on and press the other one whilst the lights are still on then it shuts the lights off?
Have i put the live feed i the wrong terminal or something
Hope you understand what i mean
how did you wire it bud, it should just be a 2 core between switches, just parallel connections, no need to actually wire them as 2 way or intermediate, thay don't work like that.
yep thats the problem fella, just parallel connect the feeds one side off the switch and the switch wire the other, I guarentee it will work, I have done this many times on push button time switches.
Reply to 2 way columbus press switch in the UK Electrical Forum area at ElectriciansForums.net
Hi All, Pretty comfortable with wiring lighting until I came across needing to install 2 way dimming with a Retractive switch. I didn’t even know...
Hi, Need some help with an odd setup. I have a large room with many lights that i separated into 2 sets. In Box 1 there is the 14/2 power in, 2...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
