Discuss 20AMP Breaker to 15AMP GFCI Wiring in the UK Electrical Forum area at ElectriciansForums.net
Currently I have a 20AMP breaker with 12 gauge wire going to a 15AMP GFCI receptacle in a bathroom. The receptacle is the only item on this circuit. I'm adding a 120v heated floor to the bathroom w/ thermostat. The specs call form only a 15AMP breaker. I plan on bringing the power to the thermostat from the existing GFCI outlet. The floor will pull only 100-125 watts so I should be fine there. My question is... do I use 12 gauge wire to make that connection from the existing GFCI to the thermostat, or can I use 14 gauge? TIA
If it was me I would use # 12 wire since it’s on a 20 amp breaker. If you come off the load side of the GFCI receptacle and it being a 15 amp, then you can use # 14 wire. I’m just saying that I would use # 12 wire.
Reply to 20AMP Breaker to 15AMP GFCI Wiring in the UK Electrical Forum area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi, My hot tub keeps tripping after 12 years of use. I'm thinking it's the GFCI gone bad. Unfortunately it's a CH 2 pole 50 amp (GFTCB250) and...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
