Search the forum,
Discuss Rewiring Medicine cabinet to accept LED light tubes in the DIY Electrical Advice area at ElectriciansForums.net
GeoPag
Hi,
I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot of money into restoring this (mostly chroming parts) I want to make sure I can get lights for it, preferably LEDs, and need to know what I should looking for. I will be completely rewiring the cabinet.
The photo shows the receptacle for the light pins. It takes a two pin bulb but it looks like the bulb just gets pushed in. The pins don’t get rotated to lock into place.
  • When I get new light sockets can I just buy a G13 base or do LEDs require something special?
  • are the sockets the same for both ends?
  • I know LEDs don’t require a ballast, do I just wire them like an incandescent bulb or are there different requirements for LEDs?
Reply to Rewiring Medicine cabinet to accept LED light tubes in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Evening. Got my hands on a pair of choke ballasts to run fluorescent tubes a few days ago and I want to see if they're in good condition. If...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hey all, So this is probably a quick question. I have some under-cupboard kitchen light tubes that are old and have clearly blown at some point...
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
