- Reaction score
- 17,113
Ok you tell me how you'd get an open neutral at any fitting on either circuit with the appropriate fuse out, if it's wired as I suggest ?
You're moving the goal posts, you never specified at a fitting.
It would be easy enough for someone to pull one fuse at the fuseboard and disconnect the neutral without realising the dangerous situation.
Your post implied that it is not dangerous as it is at the moment and that the only possible danger is that of the borrowed neutral.
No mention of the fact that the neutral conductor will be carrying twice the current it was designed to, possibly carry twice the short term overloads.
Your post implied there was no danger in a potentially very dangerous situation!
