Discuss 3 core - what colour do you use as a switch wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Black as well, because it's in the middle, so you can easily cut the strappers on either side and leave the black unbroken if you want to, for an intermediate switch
Grey - because I equate black with neutral in the old colours (and still prefer to use it as such if a neutral is required), and I equate brown with permanent live.
Recommendations are to use grey as sleeved neutral now (how I do it), in order to get us away from thinking of black that way. Not critical though, just as long as they are sleeved at both ends.
BROWN = Permanent Live
BLACK = Switched Live where Required or Strapper 1 on two way circuits (Sleeved with a section of Brown over-sleeve)
GREY = Neutral where required or Strapper 2 on two way circuits. (Sleeved with a section of Black/Brown over-sleeve as appropriate)
Where a 3 core is used on a single phase circuit (not necessarily lighting)
BROWN = LIVE
GREY = NEUTRAL
BLACK = CPC (Sleeved Green/Yellow)
as above. use grey as N is standard practice to disassociate the black from neutral, thanks to the meddling of johnny foreigner. as for 2 way switching, back in the days of sensible cable colours, most of us used the yellow for common and R/B for strappers so that in the switch with the switch wire from the light, you has red with red and blue with black. this equates to black for yellow, brown for red and grey for black
down here we used the red as common, sometimes come across the yellow used as it but not much
not where i've been. generally yellow for common.
not where i've been. generally yellow for common. but then most of us knew that the blue wasn't neutral in 2 way switching. not like some of these young sprogs today.
something to do with the water in yorkshire. we only allow what we don't want to blow over the ridge.
I had heard that the reason for harmonisation was to get
away from red being used as it is classed as a 'Dangerous' colour, it clearly worked as now every Tom, Dick and Harry thinks they can do electrics.
Still black as switch, grey as neutral.
Reply to 3 core - what colour do you use as a switch wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm trying to wire in a 4 core capacitive sensor into a safety circuit. I have brown, blue, white and black coloured cores and it's a NO sensor...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi, I'm replacing a light fitting in the bathroom but the wiring is confusing me, black brown and grey? Is black neutral and brown live in this...
