Discuss 3 way switch problem in the DIY Electrical Advice area at ElectriciansForums.net
Ziggy33
Boy, it sure would’ve been nice to figure this out before drywall. I have a book that shows all the different ways to wire a three way switch and I wasn’t paying close enough attention and the way I wired it is not in the book. There is a traveler between the switches. Is this fixable without having to run new wire? See attached. Thank you.
If the power is fed to the swich, you will need 3 cores plus ground between the switches.
Reply to 3 way switch problem in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I have a staircase about 25 feet long with two recessed lights (one up top, the other at the bottom). Each light is on its own 3-way switch, which...
