R
RutlandFox
Customer has asked for DB and new CUs for large dwelling house, WPD are putting in 3 phase to replace 100A single phase and are saying fit 80A main fuses....
Main load on all phases is Tesla wall charger 32A and a ground source heat pump 32A.
Given they are both loads that will run potentially continuous duty cycle, that's 64A, leaving 16A headroom per phase.
There are 2 CUs one with 3 RMs and one for a bunch of lighting circuits. Presuming I wire each CU to a separate phase, that's still not going to be enough unless WPD put in 100A main fuses?
Options, please!
1) Leave the existing 100A single phase in and have 2 meters?
2) Insist they install 100A supply/fuses? That's still only a 36A supply after the two big loads.
3) Split the RM CU and have different floors on different phases? Maybe even add a 3rd CU on L3?
Thx!
Options, please!
Thx!
