Discuss 4 'unknown' switches operating hallway lights not working in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone
I've come across some switches that I've never seen before (see pictures), there are 4 operating hallway downlights. The customer is currently turning hallway lights on and off using the mcb because the switches will not turn off the lights (they are permanently on).
Not really sure where to start because I've never seen these switches before... can anyone shed any light for me, or have any ideas on where I start fault finding. When you press the switches it makes a clicking noise in the fuseboard but lights do not turn off.
Thanks,
Kelly
Possible the switches may be overide switches for the lights and the lighting may be switched on via a pir sensor which could be faulty causing the lights to be on constant. This type of smart wiring is more common in new appartments etc
are these lv switches? noticed the metal plate isnt earthed and no sign of earth terminal. Get your voltage testers out. determine whether or not the switch is actually switching or not
you say theres a clicking noise in the board when the switches are pressed, it sounds like a time switch circuit, or control circuit where the switches are momentery contact type and in the board theres a small timer or contactor (the size of an MCB that can be set). if you here clicking in the board it sounds possibly that the contacts are welded in the timer/contactor or its been switched to permant overide. I would investigate whats clicking in the board..
This certainly sounds as if it's some sort of ''impulse relay'' system.
If you can hear the relay clicking when you press/ touch these switch plates then it's doubtful anything is wrong with the relay. My guess is that one of these touch plate switches are faulty, not allowing the impulse relay to change over/release...
Reply to 4 'unknown' switches operating hallway lights not working in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I'm in the process of renovating my hallway and the downstairs has a single light controlled by 4 switches. I've been replacing each switch and...
Hello folks, So my van got found after being stolen ;D Now I'm installing my own alarm on the van which is triggered when a door is opened. Im...
Good afternoon, I wonder if someone could please give me some advice on a problem I am having with my bedroom lights. I have replaced the...
