Search for tools and product advice,
Discuss 600M Electrical feed to farm house underground. in the UK Electrical Forum area at ElectriciansForums.net
Good evening.
I have been asked by a client to size and install an electrical supply from a meter position located 600M from the property and consumer unit. The client wants the supply run underground.
Supply is 240v single phase 100A TNCS.
Could anyone assist with size and cable type recommendations?
Any one else run such distances at 240v on private land?
Thanks in advance.
Steve.
Greetings.
I don’t want to be harsh, but My first thought is that if you need to ask this question on an Internet forum, then you should not be doing this sort of work.
Surely you know how to carry out basic cable calculations?
What is the estimated Ib for the proposed installation?
Welcome to the forum mate.
We are happy to help you out but we don't just give out info. How will you learn if we do that.
Give us your calcs and what you think and we will correct anything.
Everyday is a learning day.
600 meters is a long distance....
Hi,these decisions are important,as the supplier,in my experience,will not care if you make a bad choice...they will just let the owner live with it,and keep on billing...
I have had recent experience with a 460M supply,which really is a casserole of nonsense. :(
For a 50 amp SP supply over 600m you are looking roughly at a 120mm cable that’s about 15k worth of cable. If its for a bore hole pump or something obviously it’ll be a smaller load.
You say big cable, then say 35mm, make your mind up.
At 600m, I'd say the cable needed is likely to be a lot bigger than 35mm.
probably
[ˈprɒbəbli]
in all likelihood · in all probability · as likely as not · very likely · most likely · likely · as like as not · ten to one · the chances are · doubtless · no doubt · all things considered ·
[More]
at a guess. with out the loading who nose .
You got a head cold as well then Buzz (nose):tongue:
I don't think the OP will be coming back to this thread...
With the size and length of supply you mentioned the cable costs will be horrific, it will possible need to be parallel cable fed. I'd be looking at either getting the DNO to extend their MV network closer or Davesparks suggestion of stepping up to just below 1kV at the source end and down again at the destination.
How about using 'wireless power transfer'.....
In far-field or radiative techniques, also called power beaming, power is transferred by beams of electromagnetic radiation, like microwaves or laser beams. These techniques can transport energy longer distances but must be aimed at the receiver.
Sounds simple and will sort out all future shed/garage/farm house power issues...:)
100A over 600 meters is no problem now...
Hey @steve eastick
We know you’ve been looking at the responses very recently. (it’s on your profile!)
Give us your thoughts, or we’ll get bored and go to the pub.
Look, just say if you think you’ve bitten off more than you can chew. I think we’d prefer a honest update. Cheers.
Hey @steve eastick
Now he's seen my post #25 he has his answer.. He will never be back...
lots of these
Complete supposition and guesswork.
I have done a calculation and get 2.5mm cable.
Mind you, I assumed a single 3watt led marker light as the load.
Unless we are told Ib then there is NO point in wasting your calculator batteries.
Take a guess, I went with 40a, what's the point in going to the bother of this near half mile otherwise
Ok thanks for the constructive and some not so constructive posts.
My initial thought was to get the electricity provider to supply and meter direct to the property and not 600M away. When I questioned the customer it was down to cost. He was quoted 58k for a supply direct.
I am greatful for all who posted in answer to my post.
Its all in the yellow book, but unless you have a maximum load you wont get anywhere. Things to consider: Direct buried or in duct, depth of trench, loads and PF. 600M is a long way , earthing will be a challenge . I did an industrial run at 420M and the cable alone was 20K but that was 2X 120sqm 4C
Good evening.
Thanks in advance.
Steve.
Steve, have you spoken to the local DNO regards anew meter at the location. 600m Is considerable and the associated conductor size required at LV would be significant. The DNO would likely quote MV supply to a small column mounted step down transform - see what they quote.
Think his customer already done, couple of posts before yours? :)
He hasn’t, as far as I can see.
Up to now it was an ‘I’ll just bung some cable in’ thought.
He’s got a lot more work to do, with the client first.
I’m hoping we’ll get an update, but I wouldn’t bet on one arriving any time soon.
Post #40
Reply to 600M Electrical feed to farm house underground. in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Looking to buy a house where the rear of the house is the rear boundary, onto council owned land (a footpath). I want to build a new...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Just thoughts Id share my recent fun and games on my parents farm.. The electrics are old. Its a 400yr old house with outbuildings just as old...
I'm converting my old garage into a two bedroom annex. At its nearest point it is approx 10m from main house. I plan it to be all electric, UFH...
