Discuss 6mm Brown/ Grey DC cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I suppose any good cable stockist. If you want, I can give you contact details for the one we use for tri-rated.Where is the best place to buy brown/ Grey DC cable? 6mm need about 400M of each
it's in the solar forum, so chances are it'd be for running the DC down from the panels in singles using insulated and sheathed (more often referred to rightly or wrongly as double insulated) 6mm2 cable with UV resistance and high temperature ratings.... or he could just abbreviate that to dc cable and any solar installers would know what he meant.if this is LV on tray, it needs sheathed cable anyway. would help if you said what it was to be used for.
yup, red and blackCheck the regs think the colours for DC are specified in there
Reply to 6mm Brown/ Grey DC cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
