Discuss 6mm Brown/ Grey DC cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Where is the best place to buy brown/ Grey DC cable? 6mm need about 400M of each
I suppose any good cable stockist. If you want, I can give you contact details for the one we use for tri-rated.
But what's the significance of it being DC? As far as I can recall we have not used any cable specifically rated for DC.
Last place I had brown from was Tlc but never had any luck with grey. I've spoken to prysmian recently regarding colour variations in all sizes of dc solar cable up to 35mm but they won't do for less than 50,000m drums
if this is LV on tray, it needs sheathed cable anyway. would help if you said what it was to be used for.
it's in the solar forum, so chances are it'd be for running the DC down from the panels in singles using insulated and sheathed (more often referred to rightly or wrongly as double insulated) 6mm2 cable with UV resistance and high temperature ratings.... or he could just abbreviate that to dc cable and any solar installers would know what he meant.
to the OP, nope sorry, we just use black and mark up the ends.
Reply to 6mm Brown/ Grey DC cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I'm replacing a light fitting in the bathroom but the wiring is confusing me, black brown and grey? Is black neutral and brown live in this...
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
