Discuss A3 radial circuit ???? in the UK Electrical Forum area at ElectriciansForums.net
Im currently training as an electrician through ATL but i have actually been to college and done my level 1 and 2, plus had on site experience to a cirtain degree.
my friend has asked me to put a new circuit from the consumer unit to his loft as he is converting it, he wants 2 socket outlets to supply 4 lights at 600w.
my question is :
what is the best way to go about the installation? ,from what ive learnt and done in the past id use an A3 radial circuit using 2.5mm twin and earth with a 20a mcb
i was wondering have i got it right or far from it ?
thanks
Four lights at 600w? Do you mean 60w each, 600w each, or 600w total???
If you're coming from the consumer unit why not run 2.5mm for sockets, and a 1.5mm for the lights.
Socket outlets to supply lights? Or socket outlets plus lights (which makes more sense)? 600w of lights in a loft? Is it a big loft? Sorry to answer with a question.
By the way, I see this is your first post....maybe a hello would be nice!!
no i do mean 600w each, 2,400w in total i have done the calculation and current carrying capacity is 10.4347 amps
sorry i should of been more clear, theres no lighting circuit its just for the socket outlets ,
and hii all :)
As you quite rightly calculate that 4 x 600w would equate to over 10 amps so putting that on the end of a radial with sockets would NOT be the way to go.
Looks like you need 1 x radial for the sockets and 1 x radial for the lights - both 2.5mm and 16a breakers (or you could go to 20A depening on the cable routing).
And as new circuits its notifiable and does the house have RCD's and bonding in place?
my question is :
thanks
I thought the apprenticeships were through JTL not ATL?
what i have known people to do is run a 2/3 sub-board(6mm t/e) with a timer breaker in for the lights then you can take somewhere else when finished
cheers mate , theres no radial circuit for the lights , its just 1 radial circuit for the socket outlests for plug in lights , the cable run is pretty straight forward , straight up from the downstaires C/U to the loft in trunking.
He does have a socket on the staires directly under the loft on a ring main, could i branch off that by any chance without installing a new circuit ?????
Hum, maybe, how familiar are you with rings, radials and spurs?
Reply to A3 radial circuit ???? in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hello all, Trained years ago, not done much for about a decade but I've been asked by a friend to add 5x double sockets into an industrial unit...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
