Discuss addressable fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
K
kevinreilly
Hi guys
Im quite new and this is my first post :).
I wondering if you could help me on an addressable fire alarm? Ive got a new install on a convent :) next week. The trouble is that ive never done one. Ive had a look on the net and ive found a few wiring diagrams that say one leg out from the panel through all the detectors and call points and one leg back again! Is it that easy?( 1 big ring). There is a spark installing it at the moment (the conventional way) and the gather has now said to us to change to addressable but he is going to another job, leaving us to do it. The job is on price so i dont really want to be asking them how to do it. Thankyou in advance for any info.
Hi guys
yes mate,one big ring will do it,loop powered sounders mightn't give you the same sound level as conventional ones,so you might need more.You might have to look into the design of the system,how many,you can have on the loop.Interfaces are often loop driven,though some applications need a local 230volt power supply.You or your designer should consider that it is likely that a lot of sisters may be old/visually impaired/hearing impaired,and include visual beacons or vibrating bed pads,or bedhead sounders. Hope this helps.
Big help mr loy thanx again
big help mr loy thanx again
Other points to consider Kevin is that your friend may have already installed a conventional sounder circuit and some but not all panels have a conventional sounder output.Also when installing cables for addressable fire alarms you have to be carefull with keeping away from mains cables,even more so than a conventional system.When fitting off, the + in and + out are common,as is - in and -out.There is no diode in the base.The ones I am familiar with,each detector head has dip switches which you set to give each individual point a binary number,an address,and when you come to commission,you input on the panel keyboard,a location corresponding with the address.You should consult the maker of system as ,often they also insist that you install a loop isolater at the start and end of each fire zone which is formed by the fabric of the building. If doing on price make sure you get in writing how many points you are agreeing to put in,and make an arrangement if building control or others require more that this is an EXTRA.
Reply to addressable fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
