C
ChuckTH
This will be an easy answer for someone (I'm hoping) and I hope the answer doesn't frustrate me. :cautious:
Can I use AFCI breakers and AFCI/GFCI breakers on a MWBC with a handle tie? and, if so, where does the neutral go? - Oh, also, this is on a plug-in-neutral panel.
So...... just connect the neutral to the neutral bus and I'm good?
Thanks!
Thanks!
It sounds like you have a 240 volt circuit and yes if it is a four wire 240 installation then your neutral goes to the neutral bar. I hope this helps. Please explain exactly what you are trying to wire which would be a big help.
AGCI and AFCI/GFCI breakers with MWBCs...?
ChuckTH,
Megawatt,
