Discuss Air source heat pumps in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
The Mud Mouse
Hi, has anyone out there had any experience of the performance of air source heat pumps.
I am looking to fit one at my place. We are not on mains gas so am looking to find a way to economically heat the house - we currently have LPG.
The manufacturers make all kinds of claims for COP but I was wondering if anyone has any real measured performance. We have a relatively new house with underfloor heating so it will operate at a reasonably low temperature.
Cheers
There is a thread from last year regarding the legitimacy of the claims of these systems which are often sold in warmer climates have a search around for it, i also watched a tv documentary regarding air source heat pumps in our climate and the programme didn't do the product any favours leaving may customers with massive bills as the imm' heater was the back-up if temp' weren't met by the heat pumps.
It brought up many other concerns too but il leave it to you to look into it deeper.
I've got six of them going into a new build cul-de-sac that I'm doing at the moment - have to say that I've calculated for 'flat out' loads as I too have some very big doubts, and it gets mighty cold down here on the Levels!
The Energy Saving Trust started a field trial in 2008 the results of which are due ... i would contact them or seek their input on the systems and until i hear about the conclusion ill remain sceptical due to what ive heard in the past.... i belive poor design or lack of user knowhow can play a big part as to their efficiency.
I have sold one, working well, also my neighbor has one that has been installed for over a year now, he did have teething troubles but that was install issues, but still cost a lot less that their oil system to run, both of these are Mitsubishi which if memory serves me correct have no back up heat source unlike most other systems.
If circumstances would allow it is what I would choose, and PV of course.
I hope this helps.
Specified and correctly sized ASHPs do perform as well as any conventional heating system. Unfortunately the bad press seems to surround them owing to both lack of understanding on how to operate the controls by the householder and more often than not a heating installer who does not understand the principles of their operation and has just slung them in.
COPs on data badges need to be scrutinised, look out for COPs being quoted at 7 deg c, put into a heat calculation using a regional average of say -3 and you will get the likely COP.
These units are not plug and play, you have to make sure the house is insulated adequately, the flow and return pipework have to be big enough to get the heat around and the emitters have to be correctly sized for circuit temps of around 40 - 45 deg c.
Have a read of some manufacturers data, e.g. Mitsubishi Ecodan, Dimplex, Hitachi and Daikin etc.
I have one installed on my house 9kw TCAP using existing radiators no buffer tank yet (Buffer being done in summer). I am on mains gas. Coped during this winter and i am missing a radiator.
What size/age house is yours Jason? We put an 8kw into 105m2 house in 2005 (ours) and it failed miserably because we had a 12kw heat load.
Heat pumps work very well but only with careful design and installation.
Throwing one into a retrofit situation without considering the building structure and u values is a recipe for disaster . Heat losses of 50 W/m2 is preferable and look at what the heat pump is actually putting out at -3 or whatever your design temperature is. Panansonic T cap is a great unit as it maintains constant output down to -15. COP is important at this point too.
A two day course is not going to give you the heating engineer knowledge or experience that's needed for heating design at this level.
Reply to Air source heat pumps in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have a Beko DHR73431W heat pump tumble dryer that isn't heating. I'm thinking its beyond economic repair as I think the compressor has gone...
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Hello , I’m trying to further my knowledge into UFH/Rad/HW valves heating systems with air source pumps. What is normally needed outside with...
Hello everyone, I am currently in the process of estimating the electrical demand for a new construction development that will consist of an...
