W
Wrighty321
Hi All,
I'm new to this forum, so Greetings from Macclesfield in Cheshire
My first question for you to ponder, regards a client of mine who has aquired a commercial buiding with a 3 Phase supply and a meter.
Now - the building has obviously had several changes of use in its life time. There is no 3 phase equiptment in the building now and the 3 phase distribution board looks fairly unbalanced with its array of outgoing single phase circuits.
The building is essentially split into 3, 2 seperate showrooms and a flat above.
He has told me that his electricity bill is very high, and without actually seeing his bill and taking him at his word it does seem excessive when all he is running are suspended ceiling lights in the 2 showrooms
The flat above has a domestic consumer unit which takes its feed from one of the phases, and I am going to go back to monitor the load shared across all the phases, now i know its going to be difficult to balance, but with the above in mind, would it be better to advise him to get his supplier to convert him to single phase useage, or get the 3 phase meter removed and 3 single phase meters putting the flat and 2 showrooms on seperate phases.
Surely he will be paying more for the set up as it is?, and with the load being unbalanced am i right in thinking that he will be paying for the phase thats drawing the most current effectivley multiplied by 3 ?
look forward to your comments,
Regards
Wrighty
Regards
Wrighty
