Discuss Belling out in the UK Electrical Forum area at ElectriciansForums.net
Yes.
If I have a helper I use a pair of GPO 704B linesmans 'phones, much more fun and saves running about, especially if the cable is long or in a different room. You can also tell the other bloke what to mark the conductor as.
No offence OP, but I think you could have put a bit more effort into your question to help clarify exactly what you are wanting to do. Daz
connect a diode across the 2 cores at one end. then use your meter at the other. that will prove continuity and also polarity. then IR test the cores to the sheath.
Reply to Belling out in the UK Electrical Forum area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Old 1950’s appliance with 2 core, no obvious identification except that one core is copper and the other silver - any thoughts as to L & N?
Hi All, Just looking for some advice: I'm in the process of updating an old cable calc spreadsheet that helps to spit out Zs and Voltage Drop...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hello, I have bought a Bell 801 entryphone from Amazon UK and replacing my old one(which wasn't Bell 801). My old phone wiring diagram was...
