Discuss Best practice guide 4 update in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
newfutile
I have emailed electrical safety first regarding the BPG4 update : i have just received the reply
Hi,
It should be published in the next couple of weeks – it is in artwork and out for comment with the signatories.
Regards,
Enquiries
Dartlec
Bets in on what code for Type A RCDs (I'm guessing C3 for now at worst, maybe C2 if fault protection by RCD), and AFDDs where they are mandated (likely C3 for now too I would expect)
Pretty Mouth
You must mean type AC rcds? It should be C2 unless purely resistive loads present, but BPG4 have always been easy coders i think so most likely a C3 same with Arc Fault Detection Device in high risk residential building
I still think C3, as there would have to have at least 2 faults present for there to be danger: enough DC leakage to blind the RCD, and an earth fault. I'll bet codebreakers will have it as a C2 though.
Reply to Best practice guide 4 update in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Don’t know if it’s been posted yet, but here’s a link to the new guidance for I&T from Electrical Safety First; Best practice guide 4...
in the old bpg4 it stated Absence of supplementary bonding for installed Class II equipment where required (such as in a location containing a...
I see the BPG#4 has been updated and just taking a look over it now. However, I am not a fan of the new layout (EICR report style of list) as it...
Hi I'm trying to get some closure on an on-going issue I have in regards to a final qualification certificate which is the C&G 2360 Part 2. I...
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
4K
New Posts (Please Reply)
