L
LeeKerrSparky
i have been told i need to know a few BSEN numbers i know for a Mcb the bs EN is 60898 but does anyone have any ideas what the others are ?
e.g.
Main Switches
Main fuse
Old Fuse mcbs ?
RCD
Does anyone know a list where i could get these numbers from ?
thanks guys loving this forum
good use of the web ahhaa
Lee :)
e.g.
Main Switches
Main fuse
Old Fuse mcbs ?
RCD
Lee :)
BS 1361 fuses normally suppliers
BS 1362 fuses plug top type
BS 3036 rewireable type
BS 4293 rcd
BS 5419 main switch
BS 88 fuses
BS 60947 main switch
Bs 61008 rccb
BS 61009 rcbo
BS 3871 mcb
BS 4293 rcd
BS 5419 main switch
BS 88 fuses
Bs 61008 rccb
BS 61009 rcbo
BS 3871 mcb
Thanks so much
Sintra
You've helped me alot tonight i read your post on electrical dead and live testign before
think i may copy and paste it good reminder haha why pay $60 for a set of BSEN7071 regulations when
you've got sintra ay hahahaha :)
There is a list of all BS, EN, and BSEN numbers in the BS7671 Wiring regs book (BRB). But no doubt a search on't net will reveal all.
Why the hell have you got to know these anyway? You will pick up the common ones as you go.
Cheers..........Howard
thanks i have all the wiring regs on pdf files but cannot afford them as a apprentice yet but will buy all when qualify haha i don't know if i need to know all of them my supervisor told me to remeber them for some reason i think i have enough getting battered into my head at the moment lol
thanks howard:)
Lee
If you are working for an Electrical company of some description or training to be an Electrician with a company that does other things then someone must have the book, photo copy the lists, failing that scrounge an old 16th edition book, most of the numbers are the same, and all the common ones certainly are.
Cheers........Howard
They're in appendix 1 in the regs. If you're allowed, tag that page when you buy the book because it helps to be able to find the appendices straight away. Appendix 2 is statutory regs, which you'll need in the exam as well.
"BS951 Safety electrical connection - do not remove."
That's for earth tags. Sometimes they drop that question in.
BSEN Numbers
Australia
LeeKerrSparky,
Adam W,
