Discuss BT Home Hub 5 question in the Computer and Networking Forum area at ElectriciansForums.net
O
Octopus
So this weekend I set up the changes on our hub so that the kids can't use the wifi after 9.30pm or before 7am
All goig to plan until my son spots I've done this and simply uses the BT app on his phone to log into the BT with Fon "free access" wifi
So they go and allow "parental" controls to be set up then there is a way to use the wifi - DOH!!
I can't see any obvious way to turn off the BT with Fon on the router set up/software.
Ideas/suggestions please
a kick up the arse coupled with the threat to cut the plug off the router might work.
either put parental lock on the kids' phones or change the router wi-fi password and don't let them know it.
You need to opt out of this service via BT's website mate. I had a nightmare trying to remember my password to do mine.
Been on a tech chat with BT:
"The BT FON cannot be disabled for just one devices, however we can opt out from BT FON if you dont use it from
http://www.bt.com/btwifi when you are not using it. If you want to use it back you can opt in back from the same website."
How stupid is that!!!
That’s cos anyone with a BT hub router is actually providing a wireless access point for other BT customers. Eg BT with phon - so your router is most likely providing the connection
One way to solve
Change provider, set up access times based on mac addresses
Reply to BT Home Hub 5 question in the Computer and Networking Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Youngest daughter has decided to return to the nest after several years of living in the big city, now that she is permitted to work from home...
Hello fellow sparks, I’ve decided to go out on my own. Recently bought a little van and trying to get myself set up whilst keeping my costs as...
I know it's not neat, but can I simply run a single extension cable from a small (3KVA) petrol, portable, inverter generator, positioned outside...
