Discuss building control in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
derek
can any one help ,fitted sockets and lights to a laundry and sun room this was a converion from a coal shed so involved building control, finished and filled in an major works cert and handed to building inspecter ,ps im not in any reglatory body such as nic now building control have wrote to the homeowner offering to inspect the electrical work free of charge. will they charge me for the inspection do they have to accept my certs do i have to join the nic help please
if your electrical work comes under notifiable work then building control will have a vested interest in the work done. have you installed any new circuits on this job?? if you have then that is definately notifiable to building control, and therefore if the work done was notifiable to building control then theoretically there should be a charge that you or customer would need to pay, bit more information about the electrical side would help
rich e roo
Reply to building control in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Hi all, If I aren’t part of one of 2 schemes is it possible to notify building control of your work? If I’m fully qualified and competent in...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Had a lovely conversation/argument with building control this morning, the scenario is this, Completed job (4 flat rewire) EIC’s sent to client as...
Hi Did a call out yesterday afternoon. Isolated a section of the downstairs ring circuit in the new extension that had a L-E fault. Bit...
