Search the forum,
Discuss cable supports/binders... whatever they're called? in the Electrical Tools and Products area at ElectriciansForums.net
Having complete complete brain fade here...
what are the wire twisty things called the DNO use to support the concentric cables? and are they available to the trade?
I have a job coming up that needs a 16mm concentric span overhead. can anyone point me in the right direction?
no. not catenary wire to support the whole length, the drawn wire twists that the DNOs use to fix the cable at the end and wrap around the cable and china insulator?
Reply to cable supports/binders... whatever they're called? in the Electrical Tools and Products area at ElectriciansForums.net
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
On eBay you can find hundreds of Samsung (but also LG, Philips, etc.) Smart TV motherboards (see e.g. here Samsung UN65JU6700FXZA Main Board...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
