T
timo
Called to look at a job the other day and noticed the customer was having a new conservatory added to the house. The conservatory company included the sockets and light point in their price when the cutomer accepted the quote. Anyways while there i decided to have a look, the guy has run all the socket cables from a socket that is already a spur in the dinning room through the cavities in the new brick work and also said that the new sockets and light will be protected from an RCD spur.
Thought we could'nt run cables in cavities full stop.
Thought anything after one spur wasnt allowed unless everything was from a S/FCU and then as many as you want?
Also thought if you alter or add to a circuit you must bring the whole circuit upto date ie RCBO the whole down stairs ring and to check the water and gas etc are in place and 10mm (no water bond i dont think)
rant over
rant over
