If it's useful. I've just today done a "6 monthly" connector clean-out and am, as always, impressed by the difference.
Fill the connectors with IPA* from a spray can, then scrub out with interdental brushes which can get right inside the banana plug sockets (The fatter ones from Tepe brand do a nice job). Black gunk can come out if it's been a busy tester. Blow them out hard and leave to dry.
*Isopropyl alcohol, - not the type many of us favour on a Friday.
I always find that when the ohms scale zero point has been been wandering about, or variable with twisting of connectors, it becomes pretty much rock solid after this.
I have in the past experimented with a teeny squeeze of Contra-Lube, which creates fantastic results in the short term, but possibly attracts more dirt in the longer term, so I'm unsure about this one for instrument connectors.
Reactions: Rpa07
I spoke to a rep from Meggar yesterday Turns out my leads are just old and the cage mechanism with the lead that holds the probe in place had become weak and wasn't providing a proper contact. They advise replacing yearly. So they gave me two free sets
I also had them calibrated by acutest. They did a fabulous job, amazing friendly customer service so they are my go to from now on.
They took a look at my old tester and it was in need of repair. (Not worth the money) so I would like to know how it passed the last calibration. I never trusted it had been done properly, and it has sat unused since
Reactions: robd and 1Justin
Have used OSCS Mike Olding for years.Always very good service even if I send it to him. I usually send by special delivery royal mail.
Sounds like you got decent service from the two :) Although ready and wary of poor attention from large institutions,i have always found Megger to be excellent.
Just out of interest,how did you ascertain that a "knock" gave alternate readings? It was something me nan always administered to any recalcitrant mechanical or electrical device,in order to achieve obedience,which,of course,i am not suggesting ...;)
Reactions: Rpa07
Seemed to change from walking around, strap around neck so probably bounced on my tummy :)
Tested it by tapping where the leads connect to the tester...it changed the reading!
Reactions: PEG
Calibration?
Electrician Talk
Kate,
Kate,
