Discuss Can anyone tell me the main causes for lights to go off after a while? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
LeeJayyx
Like i say my friends kitchen downlights will only stay on for a limited time then turn themself off, i havnt come across this before, im guessing if theyre LV the transformer/s may be the main cause but would like to know other possible causes on e.g mains downlights, pendants. Thanks in advance, Lee
All I can think off is ELV transformers with a thermal cut out.
Too high wattage lamps fitted, meaning the transformer is putting out an higher output than it was designed for, so, as said above, they'll cut out with a themral breaker insode the transformer.
If they are on transformers, then it more than likely the lamps have been changed by the home owner, and a greater value lamp is now in place and overloads the transformer. So check how many lights per transfomer now and then find out what the transformer can take.
GLHF
Your lamp holders have loose connections after the heat has built up it breaks the current flow.... common on 12v diochroic lamps ... when replacing the lamps check for heat damaged pins i.e. not shiny silver looking.
Reply to Can anyone tell me the main causes for lights to go off after a while? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've put some new post lamps outside, onto existing wiring. They are setup as follows Switch > L1 > L2 > L3 > L4 > L5 > L6. Cabling was already...
Hello i've recently just had a re wire done on a three bed semi house, Ive noticed a few things im not 100 percent on ive spoken to the firm that...
5K
Hi there, I should start by saying I am not an electrician, but am after some advice as we have a problem that we aren’t getting any answers on...
8K
Hi, I'm looking for something rather specific and I don't know if it exists or not. I'm trying to plan a system that allows the lighting...
M
Gents, your opinion please. I am still finding my feet with commercial installation principles but this is ringing alarm bells ... My customer...
6K
