M
Matt_M
Good afternoon everybody,
I have recently installed an Electric Vehicle charging station at a hotel complex and couldn't verify earthing arrangements on the site.
The circuit I installed was a 32A radial with a Zs value of 0.24ohms, fed from a db with a Zsdb of 0.16ohms so nothing to worry about there.
The site has it's own 20,000V transformer to which I gained access, however the supply cut out was concealed in its own cabinet which has a padlock protecting the main switch and it looks as though the MET was contained inside it. In order to gain access to the MET I would have had to shut down power to the entire site (which was not going to happen). There were no obvious earth cables entering the supply kiosk (they must all run underground).
The site itself is huge and I have never been there before, the site maintenance man was useless so I couldn't find the sites incoming Gas or Water (or bonds).
How should i certify this?
Many thanks in advance.
Matt
Matt
