Discuss Car Radio, what is wrong??? in the DIY Electrical Advice area at ElectriciansForums.net
Lukus
This is really pi$$ing me off now.
Got an 03 combo van. Stock radio would light up but screen was smashed and couldn't get it to play anything.
Bought an aftermarket radio. Swapped them over without a problem, or so I thought.
It worked fine, until the van started moving then it would cut out. When I drive along the motorway, it would randomly turn on and then off again as soon as I come to a stop
Now the radio doesn't even turn on. I've checked every single fused I could find, plus more after checking Google. They are fine.
I have used a multi reader (Set on V- 200 and 20), first time it was telling me I had power (12v) coming through the harness. Ignition on and off. Now I'm getting nothing. All my reader shows is -0.00, if I'm lucky I'll get 0.03.
Again I've checked all fuses.
Everything I'm checking on my reader, it's always 0.00 or -0.00.
Tried a brand new AA battery, I'm getting 0.00
Help please!
Either you have a bad or wrong connection or the ECU is rejecting the canbus signal.
car radios normally have two 12v+ feeds. One through the ignition to power the radio, and one on permanently to keep any memory powered.
Mechanical intermittent.
May have disturbed it a few times so getting worst !
Re-check fuse holders is any labelled.
--Some fuses can be prodded for 12V in place --
Is does van have a Round power-point(X-faglighter)
Has it got power with ignition in AUX ?
(have no experience of 03 combos -habits/fittings)
Reply to Car Radio, what is wrong??? in the DIY Electrical Advice area at ElectriciansForums.net
I'll try to make this quick... A month ago the taillights all went out, checked the fuse it was blown and replaced it. A couple day later they...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Imagine me, in my car wanting to listen to loud music, i turn it up and bam it cuts outs. I soon find out that i can make it work again by turning...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
