Discuss Changes are coming, what do you all think in the UK Electrical Forum area at ElectriciansForums.net
So, ATM if you have PME and have to TT a car charger ..... Then the muppets decide if you have PME you need to have a rod
They just don't know what they are doing or suggesting.
And if it's a 10th floor flat, what then?
That's the question my boss asked, what happens if it's a flat. Do you think the extra cost of having to add an earth rod will put people off having a board change or will more people be looking for a cowboy to do it cheaper
For this reason details will be included in BS 7671:2018 for the installation of arc fault detection devices (AFDDs) to mitigate the risk of fire in final circuits of a fixed installation due to the effect of arc fault currents.
American pressure sales have worked wonders on members of JPEL/64.or is it one American import that is desperately needed?
I was refering to using a ground rod NOT bonding !
I assume you mean that plastic pipes are creating natural installation isolation from earth and nolonger providing a parallel path so it is more so essential to ensure the earth rod if used gives a good reading... you comment was somewhat ambiguous hence my reply :)
Reply to Changes are coming, what do you all think in the UK Electrical Forum area at ElectriciansForums.net
Hi got a 8 panel solar system on bungalow, changing the board to 18th edition spd board Solar feed is chased into wall so will this need a type B...
Hi, I'm back in the electrical game after 9 years break so feeling a little rusty! I'm adding an additional socket to a circuit but the main RCD...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
Hi all, Very much a novice when it comes to electrics. Anyway, we're getting an EV chargepoint installed, but before we do, I was wondering what...
