Discuss Changing Consumer Unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I am currently planning on changing the Consumer Unit in the Boiler Room of my home. The board is 17 years old, fitted with old cartridge fuse holders. I am planning on upgrading to a new amendment 3 (bs7671 - 2015) standard. The problem I am having is that I have no experience of working Live, the incoming tails from the meter box have no means of isolation. They are connected into Black connector blocks just before the Consumer Unit and then doubled together in both connectors and are connected on til 2 80A RCD's. If I can get the tails safely isolated, I know how to do all the rest.
Can anybody here advise me on what my safest option would be to give me peace of mind?
Hi OggyMac, welcome to the forum, looking at your profile and previous post it seems that you have been involved in other area's of the electrical industry and no doubt you are know that field very well, as domestic isn't your field, you may be better working along side a seasoned spark for a few yrs until you pick things up.
If you want to get a spark in and ask him to make the final connection and check your work that might be the best option as you will have done your first board change and had it checked with obvious pointers from the spark on any issues he finds (if any).
I think that would be my best bet, I do agree with you on the experience front, I previously worked for a company wiring the Ulster Hospital in Belfast a few years ago but because it was a new build/renovation to an existing building I never had to work live, I like doing dist. board terminations as i had the patience to do it right. I will stick to your advice anyway, thanks!
I must seek further advice on the building regs because when i was doing my training, any exams i done never covered all the building regs!!
The is a publication entiltled something like "The Electricians Guide to the Building Regulations" - well worth buying a copy as it does provide the salient points to sparks in relatively easy to read form!
I don't think it would help the OP Murdoch as he's from Northern Ireland which have a different set of building regs. http://www.buildingcontrol-ni.com/regulations/technical-booklets A quick look through technical document R page 46 and I think they have different requirements on heights of accessories for example.
Reply to Changing Consumer Unit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I have a job for a customer, the consumer unit is an old 3036 board and there are several holes in it giving access to live parts, I can...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
