Discuss Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Gigsy
Hi I am training to an electrician.
I am working as an electricians mate.
I have been asked to draw a wiring diagram, would anyone check my diagram and see if there are any obvious mistakes please. We will be wiring it Friday, obviously it will be checked by the electrician I am working with, but to save any embarrassment I decided to post it here before he checks it.
Im not sure on the brown of the underfloor heating valve . It is connected into the Lr on the ufh manifold . If Lr is commoned to Sl of the stat terminal then it will work .
That aside it is good
The 1st thermostat, (21 Landing Thermostat), I have wired to S-plan connector 4, which goes to the combi boiler SL/Ls. It that right or would I connect it to connector 1 or does it not matter? Is SL/Ls on a boiler a permanent Line or does it ever switch off? I don't ever want to lose power to the thermostat as it is programmable.
Ls and Lr on the ufh manifold is an un-powered relay. So the UFH thermostat tells the manifold it needs heat, the manifold closes the relay labelled "Boiler". That should then send a voltage back to SL/Lr at the combi boiler and ask it to turn on? Is this right?
So effectively it will bridge SL and SI on the boiler, during the times the UFH needs hot water.
The diagram looks acceptable to me, I would have fed the ufh controls from Ls personally.
If you take the feed from the switched fuse spur direct to the boiler and have all external controls fed from Last then when the boiler is switched off or the internal fuse blows all external controls will also be dead.
Think I'll change it, thank you
UFH stat calls for heat , Manifold relay energises brown of zone valve and pump . UFH valve opens energising orange which fires the boiler .
Reply to Check my wiring diagram in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hey all, As the title suggests I'm taking the final exam in the new year. I have my sheets to go through ready for the exam and over the...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hi all, I've been getting into electrical work these last few months, and have gone from doing rudimentary battery-switch-bulb diagrams to...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
