Discuss come back mk. your MCBs may be skewed, but this takes the proverbial in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
had the misfortune to install this today. came with isolator and RCDs. no MCBs .
as you can see, the guts are way out. caused by din rail being badly fixed. close on the left but 1/4" out at the right. all been wired up and fired up, so had to loose the din rail just to get cover on. got another visit for finishing off downlights, so will need to re-drill din rail and fix in alignment. what the buggers had done to get the lid on was to shove the RCDs and isolator to the left side. and the 6 LEDs that come on when you open the lid were no help at all :eek:. couples with needing a 3rd hand to hold the lid open whilst juggling the guts into position,
Electrical Trainee Jobbie Tel? not an electrician that's for sure
no pete. this is a brand new CU straight out of the box.
Surely somebody butchered it that way? What made the client call you out? Sorry Tel bad design then
it's a new install pete. a subbing job. as i said, this came straight from supplier.
Similar vain I tested this nasty Protek board last week and as you can see all devices are adrift from the centre spine so I refitted them only to find the cover no longer fits so had to shift them all out again.
Similar vain I tested this nasty Protek board last week and as you can see all devices are adrift from the centre spine so I refitted them only to find the cover no longer fits so had to shift them all out again.View attachment 38864
Is Protek a derivative of Proteus, Westy? because if it is I wouldn't touch it with a barge pole given the choice.
Probably from the same Chinese back yard and I wouldn't touch with a barge pole either it was part of a Periodic I was doing. The left side rcbos have rendered the left side earth bar all but inaccessible.
Pro-tek are the main budget brand sold by cpc, preston.
why on earth don't they make them 2" bigger all round. then space would not be an issue?
chint aren't too bad. plenty of room above the breakers, due to the solid internal tails not flopping about everywhere. still prefer BGand starbreaker though.
no. the breakers etc are same, but the casing and internal tails aren't. the CPN has floppy soft tails.
Reply to come back mk. your MCBs may be skewed, but this takes the proverbial in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Heating system in a local church which is basically tubular heaters under a few pews. A local company has already quoted thousands to rip all...
4K
T
Hi all, great site and sorry for the long post - I'm after some advice as I don't have total confidence in the 4 sparkies I've currently used with...
6K
