Discuss Consumer unit change certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Gazthesparky
Hi guys
i know this has been done do death, i have searched but i've not been able to find an answer. I'm having a mental block so just thought i would ask what everyone else puts.
I am filling in a EIC for a consumer unit change. I know that i'm not responsible for the entire installation just my new consumer unit so what do people put in the box that says "Extent of Installation Covered by this Certificate"
Im thinking something like "Consumer unit change please note that this does not cover the existing circuits"
what do you guys think and any suggestions ?
Cheers
As mdj said you have to test and certify all the ccts on cu change so you are signing off the installation, any remedial works will have to be carried out mate !
"CU change only. existing circuits tested and verified as safe for continued use". simpless.
Thanks telectrix just what I was looking for I just couldn't put it into words :)
I am testing all the circuits I just wanted to state that I'm not verifying the rest of the installation just verifying that my work ie the consumer unit is certificated
If you had done an EICR prior this would cover the existing circuits, providing no major issues that effect your new board, then on your EIC you can state change of cu only.
Reply to Consumer unit change certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All, I am in the middle of purchasing a small 1 bed flat in England, and have been sent a Domestic Electrical Installation Certificate by the...
I've booked in an electrician to run an EICR, I have an old unit here, whilst searching for quotes one guy said it looks ok and may not need...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
5K
