Discuss Consumer Unit labelling in the UK Electrical Forum area at ElectriciansForums.net
P
paulfreer
Got my assessment coming up and I have a kitchen rewire I have done to show, New cooker circuit, New Sockets added and spurs to cooker extractor and under counter lights. I have just done my testing on what I have done in the kitchen so when it comes to labelling the consumer unit would I need to put a date of inspection and next inspection label on even if I have just tested new cooker circuit and kitchen ring circuit? Don't want a non-conformity for something like labelling as I would feel rather stupid!!!!!
No you just need an installation certificate for the new circuit ,and minor works for the other but may be easier to put the test results down on the one certificate , you are only responsible for the work you have done if you add an inspection label it could possibly indicate the installation has been tested , if there is no inspection label on the board recommend one by adding it the the comments on existing installation and put no testing of other circuits was carried out in the limitations box , also ensure the bonding to services is in place , just ensure you have identified all you have done on the certificate
Ive always thought yes, i dont agree with it but ive heard of inspectors asking for it, nothing to stop you adding a bit more info on the sticker to indicate which circuit it relates to.
514.12.1, points you to 61, you have carried out initial verification of those circuits.
I do agree it may add to confusion though.
Yeah, wack another pointless sticker on the CU, ...if you can find the space that is!! UK's become a nation of sticker users. If it was my house, the bloody lot would be...OFF!! lol!!
Reply to Consumer Unit labelling in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
