Discuss DC voltstick in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
well if you're testing with your tongue, blow, not suck.
Hi,
An AC voltstick works by detecting the alternating electric field close to a cable. As the voltage field is static you might get the odd bleep / flash as you MOVED the voltstick past a HV DC cable but it is not reliable.
Reply to DC voltstick in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I need to understand whether a DC motor is sturdy or not. The support person told me to measure the armature and field winding resistance...
Hi. I've read much about ac vs dc but can't find a 'simple' answer. If current alternates 50 times per second in a uk mains circuit, why do live...
Hi I'm just starting to fit EV chargers as part of our solar installs. Just looking at the tester options I currently have a Megger 1711 but this...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
