Discuss Diffuse backlit label strip in the Lighting Forum area at ElectriciansForums.net
Soi disant
I want to backlight a shelf-edge label strip, so I was thinking of using some kind of surface mount aluminium channel - this sort of thing:
It needs to be viewable from close to (say 30cm) without getting your eyeballs boiled, so I was planning to run the strip quite dim. Is that likely to cause a problem of uneven light, i.e. each LED being visible?
have a look at Tagra Lighting. They make these type of strips to order.
I guess the size of the aluminum profile is similar as W16mm*H6mm. For such projects, first thing you need to make sure that it will be dotless since it is only 6mm height aluminum profile. So 240-300leds/m might be ok. Eiether to be SMD 2216 chips or COB chips might meet your demand with 2 rows of 4-5mm strip lihght. Secondly, you have to control the total lumen of the strip light, which is mainly by the watt. So my recommendation is as below:
2 rows of 4-5mm SMD 2216 LED strip light with 240-300leds/m 4.8-6W/M
2 rows of COB LED strip light with 380-500 leds/m 4.8-6W/M
Reply to Diffuse backlit label strip in the Lighting Forum area at ElectriciansForums.net
Hello all. I want to fit LED strip lights to the ceiling with 45 degree channeling and diffuser around my son’s room. As there are so many...
Hi, I'm very new to electrical but I'm ready to learn. For my first project I'm looking to setup 2 shelf racks with four shelves each and about...
Hi - sorry if this has been posted elsewhere but i cant seem to find the answer. I have an LED Strip and a smart controller. I need a power...
My local store purchased a lot of this Chinese LED striplight JH-12C for himself they are dying like flies, I offered to look at one (he has 20...
Hey, i'm looking for a small LED strip with closley spaced diodes, but then i'd like to have some kind of diffuser which is as black as it can be...
