Discuss Does the fan isolator in a bathroom have to be on the outside wall? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
atm-12
Hi,
I am apprentice electrician about 1 year and a half into my course. I have been asked to install a fan in a bathroom which I am quite capable of doing, I just need to know if I can put the isolator inside.
I have been asked to do it in trunking, so I was going to trunk from the pull switch to the fan via the light fitting depending how its been wired. I'm guessing it is against regulations to isolate inside, but it would be easier if I can.
Thanks.
Hi atm-12
i believe that if the fan isolator is on a pull cord it can be located within the bathroom but if it were a switch it would have to be outside of the room. Hope this helps
Remember it will come under part P......you will need to register it to comply with the law......although I doubt you will be hung,drawn and quartered if you dont.
I will always put the isolator in. Never seen anything about not fitting one when theres a window.
In the room outside of zone 2 or usually above the door outside, as most jobs i get are having the bathroom walls redone so its easy to install it there
Worked in a bathroom last week and the window was about 9 inches by about 36 inches, new build so right up against the next house. Even on the sunniest of days there wouldn't be enought light coming in throught that size of window. Didn't have an isolator in until I put one in.
so, to sum up. if there's a window , not letting in enough light to see the fan, you don;t need an isolator. if the client has cfl lighting , you need an isolator, even though you still can;t see it with the lights on. all boils down to the good old torch. think we all know how to use one
i always fit isolator. better overkill tan fall foul of the LABC jobsworth part peee gestapo
you need a fan ,window or not, its building regs not electric regs.isolator is because all motors need local form of isolation and a fan is a motor.switch can be in bathroom outside zone 2 if rcd protected or a pull switch.if room has no window then fan must be timer model with 15 mins run on.
Spot on. Local isolation for maintenance work. What about the perminent live for the timer? Has to be a 3-pole isolator (if the fan indeed has a perm live and switched live).
Shower unit, cooker outlets etc...local isolation for maintenance purposes.
Torch how old fashioned was working in a place the other day and an alarm company were in the false ceiling using bloody iphones as lights now thats an app NUTTERS
no. a like for like replacement does not have to have circuits upgraded to latest regs, e.g. RCD protection provided. if you fitted an isolator, you'd have to provide RCD protection to the circuit if not already there.
Thanks for that, that's what I thought, someone wants a couple replaced and I'm sat here with BS7671 and building regs book trying to decipher it, cheers
Reply to Does the fan isolator in a bathroom have to be on the outside wall? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
