Discuss Domestic CCTV system in the UK Electrical Forum area at ElectriciansForums.net
atm84
I can't access the CCTV forum on here.
I've just bought a new house and wanting to add some security to it. Can anyone recommend a decent alarm system and CCTV system?
Would like to be able to access the cameras via the Internet and iPhone.
Looking for 3 camera's max and ability to record continuous for 14 days.
Do you want to access the stored footage over the internet or do you need all the cameras to be ip addressable so you can view the live feeds from each?
I've just fitted a swann system. Cameras are 650tvl which give good pictures at day and night. Small compact dave unit, Works on my iPhone to view remotely if needed. Try to watch for systems with 420tvl cameras the quality is much lower. Ade alarm systems and veritus are decent panels, fitted loads over the years. Most people fitting wire free
try here for CCTV,,,,,,,,,MIE CCTV Limited ...and here for alarms,,,,,,,,,,,,,,,,,,,,,, risco.co.uk
Hi Marvo thanks for the reply. What would you recommend? I would ideally like to be able to access the stored footage over the Internet. I was thinking worst case scenario: someone breaks into the house and then steals the camera hard drive etc and then I wouldn't have any footage.
Installed a 4 channel Swann system on our house only a couple of week back. It's all set up to remote view on the phone. Covers all the exterior of the house.
Live in Suffolk, a nice area but you never know. There has been a few attempted break in's lately. Don't like the idea of someone snooping around so hoping the camera's will be a good deterrent.
Live got a solid brick room in the middle of the house, then lined with 18mm marine ply for good measure, solid wood door, two 5 lever Yale locks and a 1200lb magnetic door lock. In the room is the CCTV recorder, house alarm, Internet router etc and phone line. A hefty ups supply for the CCTV and router, and battery backup on the mag lock. This way if someone broke in and killed the power I'd still be able to record and remotely login to see what was going on, plus the alarm would have notified me too. Oh and no handle on the door and reinforced edge.
In the room I keep all my tools as I don't keep them in the van.
Ive got 8 650tvl cameras with extra ir flood lights, three of which point at my van, oh and I use smart water.
Hopefully nobody will ever break in, but if they do it will or should be significantly more difficult to steal my tools or CCTV recorder.
Paranoid, well maybe a little. Oh and the mag lock doesn't have a key pad, it's got RFID entry and you need to put the fob in a certain place to release it as the reader is built into the wall. I thought having a keypad on show, someone could rip it off the wall and possibly open the lock.
Oh plus there's heavy duty hinges and 4 dead bolts in the hinge edge.
you serious?!
I'm not sure exactly what you are looking for but I installed a wireless HD Foscam unit last year. It needs a local power supply or you can use POE if you wish.
There are a few apps that allow remote access, you just need to forward/open the relevant port.
you serious?!
Yes totally, I have at least £10k of tools in that cupboard and equipment to incriminate people. I would rather make life difficult for a thief than loose all my kit, I know its insured, but its not the point!
Over the top, probably yes, but when I go on holiday I feel better.
Reply to Domestic CCTV system in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi I'm having a full house rewire. I want to have mains smoke alarms, heat alarms, carbon alarm next to boiler, internet connectivity to notify...
6K
Hi all, this one is for the cctv gurus Installing a cctv system with 14 HiKVision is cameras. 13 of which are via wireless bridges as it is a...
