DIYJO
I removed a double socket to do some plastering in my utility room. After putting insulating tape on the 2 live wires and 2 neutral wires I turned the circuit back on at the fuse to stop the freezer defrosting. As I was about to start plastering I went to tuck the wires out of the way and got a shock from the 2 exposed earth wires which had originally been fixed together in the back of the socket. I have felt 240v enough in the past to know that this shock was getting on for that amount. I tested it with a pocket meter and it came up as 170v. The washing machine and tumble drier were plugged into an adjacent twin socket, turned on at the mains but not at the appliance. After unplugging the drier the voltage in the earth wires dropped to 70v and swapping it so the washer was unplugged took it to 130v. With both plugged in it went back to 170.
I don't know if it is relevant or not, but during my investigations I discovered that there was continuity (buzzer setting on my newly re-found toy) between the Neutral and Earth on the whole house. Maybe I just learnt something or maybe there is something amiss?
Back to my main point. I discovered that the whole loop that serves the utility room had been wired so that the Live and Neutral came into the room (which has three sockets), went into a blanked off terminal block, round the sockets, back into different terminals in the terminal block, then out of the room again. However the Earth wires at the block all went into one terminal, including the one from the metal casing. Re-wiring it so that the Earth followed the Live and Neutral exactly i.e. 2 of the earths joined separately from the others made the voltage under the original conditions completely disappear.
My questions are:
1. Would it now be safe???
2. Where did the voltage come from?
3. Where did it go to?
4. Is it normal for the earth to connect to the neutral? (BTW This only occurs when the electric is on at the main fusebox but whether or not the fuses are tripped / out)
5. Surely 2 appliances cant both bee faulty to the point they're emitting a set amount of voltage constantly? Or can they? Are they designed to dump voltage to earth when they are on standby?
I need to get a real electrician to look at it properly but I would like to know for peace of mind and out of curiosity.
My questions are:
