Discuss Earth voltage in the UK Electrical Forum area at ElectriciansForums.net
B
beats
Good evening
i'm currently running a commercial site of a new gym. We have installed lighting trunking with thorn pop packs direct onto the trunking.
When testing continuity at any db's my tester is flashing up a voltage of 009v when testing to earth (was testing a ring r1+r2). All circuits have been mega'ed and are clear and all bonding is in place. When the mccb is turned off to two of the three lighting db's the voltage disappears. The system is tns 3 phase
Has anyone had a similar problem before ?
thanks
Probably just a coupled voltage from other circuits running in close proximity. If it goes away when you switch off the other circuits then perform the tests like that. You could check the stray voltage with an analogue tester if you're worried about it, chances are it won't show a reading.
Reply to Earth voltage in the UK Electrical Forum area at ElectriciansForums.net
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Have only recently gotten in to testing. Doing an R1+R2 on a lighting circuit but instead of producing a result my tester clicks over and over...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
