Discuss Eicr codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If it’s the written exam in question my paper had a table of four faults and we had to fill in the blanks, one being a code and also a regulation number to back it up. I remember one in particular was quite obscure to find. The visual exam, aka the photo part, the photos were quite dated and not exactly 4K quality, and how the C&G had coded them, they were certainly more lenient. When is your exam, have you completed the practical part?
just to hijack the thread, apologies to anyone and everyone, had this today on a EICR.. 3 x 3 phase DBs along with 3 x 3 phase henley blocks mounted on a 4ft. x 4ft. ply board. board rotted away due to a leaking drain (since fixed). getting to the point where the equipment will be held up by the cables. all 3 boards have SWA cables (correctly glanded) along with a load of T/E. can't see any danger so giving it a C3 with the caveat that if it deteriorates any more it would escalate to a C2. your thoughts, gents.
Picture??
soz pete. no pics. just imagine a sheet of 1/2" ply disintegrating.
If everything mounted was secure then there is no code in my opinion but I would maybe put something in the covering letter to say about the degradation of the wood in which the equipment is mounted to.
exactly what i done. even if the board gets worse, the cables will hold the gear up without undue stress. gave it a C3.
it is secure at the moment, but any further deterioration of the ply board would leave the DB supported by the cables, some of which are SWA, correctly glanded and supported .
Reply to Eicr codes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
EICR picked up no continuity on cpc on 3 pendants fittings in a grd Floor Flat. Zs measured @ other pendants & complies. Different opinions on the...
Hi Guys. If carrying out an EICR you are unable to find a UFH circuits spur, is the EICR still passable under some type of limitation? Or is...
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
