B
bigbaddave
Recently got the job of performing EICR for estate agent, now there are two of us performing them.
However one property in particular is a property that a member of staff is purchasing and then to rent out in Westerhope. The other spark has deemed it unsatisfactory for the following.
Socket for fridge inaccessible for isolation. Quoting for new socket along with fused spur above the worktop
Cable too small on cooker circuit.. Fed by 4mm cable on a 30a 3036. Its only a feeing a oven not a hob. However regardless of what the load is providing its protected by the 3036 then how can it be deemed unsatisfactory.
Main bond to water correct size but loose connection.
No RCD protection on anything, quote for new RCD consumer unit.
Quote for remedial - £550 + Vat. The above work will deem the install satisfactory.
After chatting to the guy buying the house he only wants the install to a satisfactory condition in order to rent the property out and has asked for a second opinion..
