Discuss EICR meter tails coding in the UK Electrical Forum area at ElectriciansForums.net
Can anyone give me some advice on coding I recently carried out a EICR on a Commercial premises (communal areas of a block of flats) 3 x DB's all single phase with incoming 3 phase supply with 100A type 2 b fuses with 16mm tails going to each DB - personally I warrant this a code 2 any thoughts and reasons please
Ideally would be 25mm but there must be hundreds of thousands of houses with 100a fuses and 16mm tails. Look at length of tails and max demand but don't overly fret. code 3 IMHO.
Yep seems a simple solution there, just get the fuse lowered to meet the flats max demand or cable carrying capacity after considering the relevant factors!
Reply to EICR meter tails coding in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
I’ve got a job to quote for turning 1 big flat into 2 smaller flats. The DNO are looking at installing new meters in the communal area. I need to...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
