Discuss EICR & the greedy Architect in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think I would be checking if the architect is a member of any of the professional bodies (RIBA etc) and report his methods to them as he certainly doesn't appear professional
UNG has the correct line of complaint to go down here. If all that has been stated is correct, then clearly this Architect is not acting professionally both on a technical basis or acting in the best interests of his client.
Unlike all your scam providers, Professional bodies such as RIBA will take notice, will investigate and will take action if the case is proven!!
more likely an Audi........ Arsehole Uttering Drivel Indeed.
If the architect put in a price for the wiring (that was higher than yours) surley that says he knew the wiring needed work. How can he turn round now and say it is OK. Sounds like he has gone to the customer and undercut you to get the job. He sounds like the sort of guy who needs darts in his tyres.
Sounds as though the architect has overpriced for minimum work (that doesn't involve chasing walls and ripping open floors) and your spec would show him up. He's also managed to sweet talk the client in some way. If you have full confidence in your diagnosis against his, the Health and Safety Executive should be your next port of call as the property is to be a rental and the landlord therefore has a duty of care under the Electricity at Work Regs (and others)
PJ
I am sorry m8 something is wrong here your post states that he priced for a rewire he had allowed for in his quote and then you state he said it was safe , it cant be both can it ?
"It turned out that the architect had been asked previously to draw up plans for this house for a refurb and that included the wiring which he had submitted a price for. I had came in lower than his rewire price and he wasnt happy.
I received an email from the owners telling me they had spoken to the architect and his electricians had advised that there is absolutely nothing wrong with the wiring in the property and it was totally safe????"
Hi Bryanh
The contradictions in the OP just refer to the contradictions in the architect's and owner's 'story' as far as I can make out :thinking2:.......
Reply to EICR & the greedy Architect in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
